For most of my lighting needs I use motor winding wire it is coated and very very light, have to mark - and + as the wire is not colored, and a JST connector to plug into the balance lead. How you wire the JST connector determines what voltage running to your lights.
Yes, I sometimes use the balance plug myself. I bought some female JST XH sockets so I can solder to one cell, two, or three . I have used them to power VTX. You are only getting 4.2v for a 5v cob light though , so not quite as bright, and if connecting to one cell and you are obviously running down just one cell of the lipo. Not dramatic if it's just a few milliamps though. And as I said just 4.2v as opposed to 5v from the RX. Easy too. For lights with bigger current I've also used a 5v bec..
The sockets in the pic can be modified so they will plug on 2s or 3s
The advantage I was pointing out is if it's only a short Cob or LED you can use a spare channel on a receiver. You could even assisgn a switch to the channel and turn it on and off.
