Solved compability question(question at bottom)
THADUDE
And I hate to ask this but what will i need to do once I receive all of the parts. I'm sure that theres a youtube video but if you could outline the basic steps that would be a big help.
ElectriSean
Eternal Student
I haven't tried that one, only Velocidrone.
A bunch of soldering and assembling, followed by configuring ;) Joshua Bardwell on YouTube just finished up a complete build series, which won't be identical to your build, but probably pretty close. He has many series' about wiring and setup you should check out while waiting for your stuff. Don't hesitate to ask questions :)
FDS
DRL sim is OK. It will still be better than crashing for real.
I would advise more than one battery be on your list, it’s frustrating to wait all the time to recharge and you will only get about 6 mins out of one pack. Also when you buy lipo the shipping cost is higher anyway, so might as well put more in there.
Basic box goggles like the Eachine EV800 series will work fine for learning.
THADUDE
ok thanks. i have watched the joshua bardwell $120 drone build and im going with that setup because the plan is explained
FDS
I wouldn’t buy an Eachine Wizard.
Also for your first set up it’s a good idea to buy from a hobby specialist like Race Day Quads so you have a real customer service available if you have problems.
Goggles are fine.
ElectriSean
Eternal Student
im not gonna beat on the quad im gonna go easy on it.
You are going to crash, many many times. I had a Wizard, and at the time it was okay, but the camera is garbage, the motors are weak, the frame is weak and the FC is outdated. You are much better off with JB's build or the TBS package you specced earlier.
  • Like
Reactions: FDS
FDS
There’s the reasons why not.
I see so many posts “my wizard crashed and now it’s dead.” Most of them are not talking about Harry Potter.
FDS
Its not a good starting quad at any price, sorry.
If you want to get flying cheaply and with low repair costs and cheap batteries check out toothpick class quads. I fly my Larva X all the time, it does all the same stuff as my 5” but it’s tiny and I can fly it places I can’t go with anything else. There’s lots of sub $100 micro quads that fly much better than the Wizard. Many are Flysky compatible too.
FDS
See edited comment. Pre made 5” is all over $200 for anything worth flying.
Making your own isnt that hard, better to do that and know how to fix it with 5”, stuff breaks all the time. Nature of flying something with no inherent lift, any mistake ends in the ground!
FDS
That’s not as good as Bardwells one. The motors are very cheap, the camera is not great (important as you see through it) the radio is not what I would buy, as you are stuck with a closed system protocol that means only radiolink receivers will work, which zero other quads have. The quad is OK but you could have a superior radio and build your own quad for the same money.
I bought my set up gradually, starting with the frame and TX, then I had something to tinker with and could fly sim or nano quads whilst I got the rest. Next I got the FC and ESC’s, hooked those up and set up the board, then the receiver and motors, so I could get it bench armed and hover test, then I did the FPV set up last. That initial build cost about $160 and flew superbly. Sadly I lost it after 4 months but then knew how to build another.
