Arunabha42
So I will be converting a generic 600W desktop PSU to a power supply for charging LiPos. I have tested it powers on by pulling the green wire to ground and the yellow wires (12V rail) is providing 12V output.
The PSU I've got is rated at 25A on the 12V rail, which is 300W.
1. I want to use a 300W charger. There are many yellow wires in the wiring harness. Will I have to join all the 12V yellow wires to get the full current out of the 12V rail?
2. Also, if I want two 12V outputs to connect to two different chargers at 150W each, how should I go about joining the yellow wires and ground wires to their respective banana plugs?
Thank you.
Thank you.
