I would like to connect a alarm to my Gremlin. But I just fried my flight Controller trying to do it. I followed the instructions provided with the alarm. Didn't work or I would be a happy flier right now. If someone wants to help me tackle this problem who has more experience with flight controllers and the wiring involved I would HIGHLY appreciate this.
Reason why I want to do this... I lost my first gremlin in a farmers field with grass that is higher than my knees... and it rained the next day. So it is inevitably GONE.
I would like to connect this 3 in 1 lost / voltage alarm into the Femto F3 Flight Controller:
Here is this wiring scheme for this alarm:
Here are the directions for the wiring scheme:
Battery monitor function (F1)
Hold the button 3 seconds to enter the setting of the voltage threshold.
Press button to set the alarm threshold between 3.4 ~ 3.7V / Cell (red LED).
The value will be saved & exit if no action within 10 seconds.
2. Discovery buzzer function (F2)
It is easy to use the function, just plug it in one Aux channel (e.g. Gear). Move the toggle switch to one side or another side, the BM3in1 will alarm "BeepBeepBeepBeepBeep" & blue LED blink.
3. Signal loss alarm function (F3)
It can warn you if you turn off the transmitter first by mistake, if you have trouble finding a model in the long grass...
You can use combinations, For me I would like to use combination of F1+F3
So I have a voltage alarm to protect my battery, and a alarm for if my quad looses signal.
If anyone want to take shot at this or explain to me what I need to do please I would appreciate the help. I followed th F1+F3 diagram on 2 Femto FC now and fried them both. You can rule out that I created a bridge of any kind, That's why I did the second Femto FC. to rule out the possibility. I took my time and wasted 4 hours soldering the 2nd FC to make sure it was done perfectly... Used a multi-meter no "BEEEEEEP!!!" so I said alright here i go, Pluged in a batter and "poof" magic smoke.
