Connection issue
DomMPaone
i have the Spektrum DX6e controller with a Spektrum Quad Race serial receiver and the controller is binded to the receiver (because the orange light is solid), however the receiver will not relay information to the flight controller which is a naze32 im not sure if they are compatible and i'm pretty new to betaflight configurator (if that is one way it can be fixed)if anyone can help me that would be great!
ElectriSean
Eternal Student
Assuming your connections between the Naze and the Rx are correct, in Betaflight, in the ports tab enable Serial Rx on UART2. In the receiver tab set the receiver mode to Serial, and the Receiver provider to SPEKTRUM1024 for DSM2 or SPEKTRUM2048 for DSMX.
DomMPaone
I tried what you said to do on beta flight but the problem is still occurring could it be a connection problem?
DomMPaone
Here's two photos do you need anything more specific? IMG_0640.JPG IMG_0641.JPG
ElectriSean
Eternal Student
Yup, you are connected to the wrong place. You need to connect to the Spektrum Satellite area of the board, as shown in this image:
From left to right the holes are +3.3V, ground, signal.
Should also note that the way you have it connected now is giving it +5V, but it only wants 3.3V, this can cause bad things to happen ;)
DomMPaone
I installed the wires as said and the controller connected but only beta flight is picking it up if I go to receiver and move the controller it picks it up but if I unplug it from betaflight the drone doesn't respond it might just be a low battery but I'm not entirely sure
ElectriSean
Eternal Student
By default it's set up as stick commands, but I recommend putting it on a switch.
To set it up on a switch, you can follow the FT video https://www.youtube.com/watch?v=aFf3ybXDuYs starting at about 12:30.
You should actually watch it all, and Painless360's awesome series on YouTube to really get what's going on, it's a whole world of stuff to learn :)
JimCR120
Got Lobstah?
Site Moderator
My son has gotten into quad flying and the stick arm/disarm idea makes me scratch my head. Why would anyone ever want to put a disarm command on a major flight control? I agree put that on a switch.
Craftydan
Hostage Taker of Quads
Jim,
Mostly because older flight controllers only had 4-5 channel inputs. They didn't have the channels to waste on a dedicated disarm, and most radios didn't have the programming to multiplex it onto the mode channel . . . assuming the board even HAD a mode input. Stick arming is a bit old-school, but while it seems weird it hasn't become obsolete.
I get where you're coming from, but these are multirotors -- they do not glide. Arm and Disarm commands are done at minimum throttle, so as you are "disarming", either the craft is on the ground or rapidly approaching it.
Until the advent of "air-mode" (where a free-style pilot may actually drop the throttle to zero while inducing a pirouette) there never was a risk of a pilot inadvertently commanding a disarm. The only concern (and really the reason arming switches were included) were tricopters where the user wanted to disable motor_stop (tricopter arms to idle throttle -- slowly spinning -- but the tail rotor is yawed hard over).
Personally I cringe at "flip a switch and the motors start spinning" that the popular combo of a switch arm without Motor_Stop gives you . . . but to each, his own.
JimCR120
Got Lobstah?
Site Moderator
Ahhh, motive that make sense. Not surprising that you had the info.
I'm not big on switches spinning props either. On my radio I have a 3 position switch assigned as my flight mode switch with one of those being a safe "Throttle Cut" position, even for my little Inductrix. My son set up his Vortex on a switch so that though he still arms/disarms with the left stick, he can only do that with the switch in that position. Of course this function was implemented after shooting his brother and me snowboarding and then accidentally disarmed the quad inflight.
