Conscendo Evolution 1.5m Bind n Fly Aileron Servos move thsame way after fuselage replacement
Captain Video
Conscendo Evolution 1.5m Bind n Fly - Aileron Servos move thsame way after fuselage replacement. The left aileron servo was making a clicking noise after the fuse was replaced following the last tussle with the ground. I replaced the servo and both aileron moved the same direction. There is a servo wire "Y" cable that is still in the Con Evo but no matter what I do (so far) the servos always move the same way at the same time. Does anyone have any thoughts on this matter. I would think as long as I have been flying, I should be able to solve this problem.
Thank you in advance.
Captain Video
Bricks
Each aileron servo should have it`s own channel to work correctly. If each is on it`s own channel then something in the transmitter is not set correctly.
Captain Video
Thanks for your input. I pulled the other servo out and found the servo was wired backwards. Replaced it and everything is golden now!
Foamforce
It was wired backwards internally? As in, the servo was defective? Because plugging the servo wire in backwards would just make it not work. I’m curious!
