Continuity Check on Naze32 rev5
zakovich
Hello,
i'm new to soldering and electronics in general so bare with me please.
After soldering my pins on the Naze32 the continuity Check Pings between -VBAT Pin and -TELEM Pin.
also I get a Ping between all my Motor GND Pins and same is the case with the Motor + Pins (the Signal Pins are not connected)
did I short anything ? when connecting my Board with the miniUSB it works fine and I can connect with CleanFlight App (all sensors looks good as well as the Calibarations).
Thank you
ZoomNBoom
There is no problem. Grounds (-) can be shared, and both the + and - on servo/esc connectors are always connected.
