After soldering 4 Kiss ESCs for a Alien 5 inch I decided it would be a good idea to test that there was not a short between positive and negative to be on the safe side.
I hooked the multimeter up negative to the com and positive to the positive terminal and set it to buzzer. Touching the two probes together it would beep as I expected it too. I then tested it on the escs positive to positive and negative to the negative terminal and it would beep. There are no wires connected to the motor leads. After watching T Bones Drones fixing a broken esc he noted that there was a short between the positive and negative on the esc causing the problem and it beeped indicating continuity.
Concerned I overheated while soldering even at only 300 degrees and little contact time I also tested a fifth spare esc I bought and haven't touched and it was the same. Since It was beeping I decided to switch it to a ohm test and tested all of them again. There was 5k ohms resistance between the positive and negative and 0 ohms between the small ground and large negative (which makes sense).
(I am using an old analogue multimeter not sure if I am using it correctly, I did calibrate the ohm test though.)
Note if I used the negative on the positive port and the positive on the negative it would not beep, I thought that would be due to the diode though since they only allow current to pass in one direction.
What is the correct way to do this or did I do everything correctly? are my escs fine?
(I ended up testing a plush 25 amp and the same thing occurs with that one which I use to use on a plane occasionally so I know it works.) I'm assuming I did something wrong in testing. If I reverse the probes it doesn't make a sound so based on the esc I know that works and the esc I haven't done anything too yet they should be fine. I will use one of those car lights when I first plug it in though. Hoping logic plays to my side.
