converted pylon racer
bracesport
I was thinking about these ships that can fly faster, so I looked around for some airspeed sensors and came across this one from FRsky, the ASS100 (interesting name) - it is good from 0-300 Kph so that should cover my speed range (slow) - now I just need to figure out where to plug it in!
bracesport
I have been enjoying the flight simulator and especially the gliders with air brakes (crow), so I have been dreaming of adding them to this ship which is quite fast and I am a bit scared of the landing speed! My mate @jonoashton can do it but I will feel safer with some brakes!
Today was the day - out came the knife and the beginning of some flaps - I was surprised the wing is balsa sheeted not FG - the TE of the wing is hollow so I needed to build up the open side of the new flaps - A little balsa strip is now glued in place.
I am thinking I may as well put them on a seperate servos so I can run them as full span ailerons or flaps.
Step one completed! :)
bracesport
A bit more progress - yes I used my micro cable ties again, however this time I used a slightly beefier one given this ship is more of a beast - remember to ‘V’ the centre with a blunt chisel for the folding point.
Drilled the pilot holes and glued the cable ties into the flap side - added some blocks with CA to pack the wing side.
bracesport
Servo holes cut and there is just enough room to fit them pretty flush with the underside of the wing - control horns are recycled 3D printed ones and I added some balsa standoffs to help glue them in more securely - every thing seems to fit well so I got glued the servos into position.
