Here is dvr video of my FPV maiden with the Twitchity Tricopter on 4S. Note, this is really just a run to test signal and video.
It also doesn't rotate (flip) quite as quickly as I am used to. :black_eyed:
This is the default tune from triflight WITHOUT a tail tune.
I learned a TON on this build. I replaced everything except the motors and the frame. I can't use the landing legs I have for it as I am using the Baby Tricopter tail tilt mechanism. I had to modify that to get it to work on this frame but it seems to be holding up nicely.
The copter is a bit sluggish in the first 10% of throttle but it picks up nicely. Most of this was flown 25% - 30% of throttle. These motors are ancient SunnySky 2204 2300s from my first build of this copter and nothing got hot although I didn't push it.
I also manually tilted the camera to about 25* which is a bit faster than I am used to.
To build this I had to learn BlHeli Suite. I also tried the app but with all the problems I had I used the suite because there are more tutorials online. I had to tinker with BetaFlight because Triflight doesn't work well on Cleanflight. I used Zadig for the first time to get my Taranis to connect to Windows 10 and again for the F3FC USB driver. I also made my first ever CCTV OSD cable and learned how to tune a camera. All the others I have had just worked out of the box.
HUGE thank you to all the folks who helped me troubleshoot bad drivers, bad ESC, and Cleanflight problems, particularly LitterBug.
Also a shout out to Twitchity. Wherever you are man, you made a heck of a frame.
