Raptortech
Foam Addict
Hope my title caught your attention!
It is true: I am building an aerial photography craft of epic proportions. Right now, I have a setup in mind, but before I go an throw down $7000, I thought I'd chat with everyone first.
So my plan (as of 6/29/15) is to build a custom X8 frame.
Motors: T-Motor U8-10 (170kv)
ESC: T-Motor 80A HV
Props: 22x6 CF
Batt: 12s 16000mAh
My calculations give me a 15 minute flight time if we load airframe up with about 20lbs of camera equipment (RED Epic, Movi M15 Gimbal, big lens, Connex FPV, etc). This is acceptable, but ideally I would like to reach my initial goal of 20min flight time with 25lbs payload.
If anyone knows of any comparable motors outside of the t-motor brand (I was unable to find any other than some data-less HK thing), please let me know! Also, ESC timing will likely be an issue, so if you have experience tackling that, any input is much appreciated.
I've done a fair amount of research into this and have found various configurations which could theoretically make the mark (for example using a conventional octo instead of an X8), but I am limited by cost and my transportablility. For the sake of discussion, let's say less than $8000 for the airframe and it should be able to fit in a decent size trunk of a car with the rear seat folded down. Another solution I have been considering is an X12, but I'm hesitant as that will significantly reduce the overall efficiency of the aircraft.
ESC: T-Motor 80A HV
Props: 22x6 CF
Batt: 12s 16000mAh
