Cut servo wires
As I was taking apart one of my build I accidentally cut the wires to one of my servos. I tries twisting them together and it didn't really work. I was wondering if I could somehow solder them together and use heat shrink to repair the damage. Let me know if this is possible.
Thanks.
ps. I apologize for the blurry image.
FDS
You can solder them, they are pretty thin. Insulation is a must, heat shrink is bst. If you have excess wire you can just crimp a new servo plug onto the end. The silver pin parts of the plug come out the plastic insulator and can be replaced, they are usually a JST pin. That is the best way to do it.
#4
Oh, sorry! We posted at that same time!!
Yes, you can repair this. I have made this repair many times, I don't bother twisting the wires, the solder joint alone is sufficent.
You need to heat shrink each wire separately to prevent a short. OR Stager the wires so each solder joint is slightly separated form the other, then one heat shrink over the bunch. You don't want these wires to ever touch each other. If they do touch, smoke may come out of something.
Bricks
MMMMMMmmmm the smell of burning plastic and electronics. :love: :giggle: :poop:
