dkj4linux
So....
I've been mulling over this concept for quite some time, Monitoring both V1-engineering forum and here. I've finally decided to jump in head first, and build a machine. Dave, thanks for answering my questions in the past. Although I feel more at home in the FT forum, I know V1 forum is also full of helpful people as well. I'm going to apologize in advance, for my question, as I feel as much time as I have spent in the forums I should know the answers already, and yet I'm only looking for confirmation that I'm on the right track, and I didn't want to make a bad name for myself in the V1 Engineering forum.
My needs are building a "foam ripper", to be able to handle 20x30 sheets. And yet I'm seeing value (from the forums) at not building the first machine this large to handle this right out of the gate. I would like to some day be milling material (wood, MDPE, others). Dual end stops seem to be highly recommended, but not for the beginner. So I wanted to make sure I had the parts, and capability, but don't plan on this being used on the initial build. Although with my anal tendencies, would like SS rails, I believe I'm starting with conduit. So currently my shopping cart appears like this:
MPCNC Printed Parts - 23.5mm -Burly
Mount_Option: Dewalt DW660 Mount
Mount_Nut_Size: #6-32
GT2 6mm Belt GT2 6mm Belt
Mostly Printed CNC Parts Bundle - 6A / RAMBo Dual Firmware & Wire kit Mostly Printed CNC Parts Bundle
I have everything needed (except conduit, and maybe some nuts and bolts) as long as I have a way to have a friend print out some of the missing pieces on a 3D printer, correct? Or is it desired to add the LCD screen, to print from SD, instead of host computer?
Sorry to ask this here, I know the V1 forum is probably the more accurate place. Again, just feel more at home here.
Steve,
As I said in my previous post I think it important you identify the primary purpose of the machine you want to build... and then build it for that purpose.
A few posts back, I dismantled a 4' x 3' MPCNC I built early on (and was using when I started this thread...) for needle-cutting planes. It worked great but was really suitable for only light loads... needle-cutting, pen-plotting, laser, etc. Three and a half years later, I am using my version of a LowRider-inspired machine, Moebeast's Foam Ripper, for needle-cutting planes... and I think it's far better and easier to use for that task than the MPCNC I started with. Nothing at all against the MPCNC... the Foam Ripper just didn't exist back then. The Foam Ripper is less expensive, uses fewer parts, uses common conduit, and is simpler to build than MPCNC... and is actually semi-portable and less intrusive to precious shop space.
The MPCNC, especially the Burly version, is more versatile and strong enough to carry the Dewalt around for light-milling tasks. You really can't go wrong building it for that... but I'd recommend sticking with a small foot-print rather than one large enough for needle-cutting 20" x 30" foam sheets. It'd do the needle-cutting just fine... but wouldn't be as suitable for the milling you eventually want to do.
So, I'd build one or the other, depending on what you want to do first... foam-cutting or milling. And, then plan on building a second machine in the future for the other task. If you have sufficient space for both machines, you'll never regret building both. Building these machines is a great fun and educational experience and, in learning to use the first machine, you will identify things you'd like to see in a future machine... that you'll now be better prepared than ever to build.
Be careful... it's addictive.
-- David
