Hi Wild Bill. That is really first rate. Gave me a good giggle too!! Thanks for jumping in. We have a right laser crew here now!
Hi Rob: I was just thinking about air cooling. My safety goggles are pretty dense so I just see a bright spot through them, but I can still see little shards of laser light bouncing off smoke particles. I think for simple tests I could cable tie up my airbrush which should allow some good comparitives. I'll get cracking on that tomorrow and see how it goes. I the longer term I'd like to tie this in with an extraction system too. I was messing around with lots of material today including foamboard and I did not like one little bit the smell coming off the burned foam. I certainly wouldn't want to release large quantities of that in my workshop.
..anyways as mentioned I was messing around with anything I could find with mixed success.
Clear Acrylic: Fail. The last just passes straight through and burns the spoilboard which in turn melts the underside of the acrylic but not in any useful way (sorry havent got a photo).
Aluminium Foil: Fail. Doesn't even mark. Even full power 50mm/min and 10 passes
Clear PETG: Fail. Same as clear acrylic.
Balsa: Big success. 300mm/min full power 1 pass. I can definitely see me getting into a bit of balsa bashing after this success.
FliteTest Waterproof Foam Board. Cuts ok but leaves too much of an undercut to make this a viable alternative to the needle cutter.
400mm/Min, 100%, just cut through the paper and left a channel exactly like the rightmost cut in the image below.
200mm/min (pic below) 1pass (righmost) through 5 passes leftmost. Might be interesting to try again with an airblast and see if that helps. I should mention this was just sitting on MDF hence the lower paper burn in.
Posterboard: cuts a dream at 700mm/min, 1 pass, 75% power. (Sorry no pic).
I use Mach3 and it doesn't work very well with image2gcode. However I came across a Mach3 plugin to rasterise images via a laser so I'll have a play with that tomorrow and see what damage I can do.
Finally I'd just like to wish you and your families a safe, peaceful and healthy 2017. I wish you all lots of cool gadgets and look forward to sharing lots more experiments!
