Video of the first full sheet cut!
https://www.youtube.com/watch?v=c1JVG0g0JHw
It worked pretty well, my z ended up off a little bit so there were still some bits holding it together on the bottom, but I ran through it with an xacto and in a couple minutes it was perfectly fine.
So this is related to two things, one, that my stepper motors get very hot, especially my smaller set. So hot that I just added heatsinks to them. And two, that my pineapple coupler never fit my threaded rod very well. It was mostly held together with super glue.
I'm printing a new smaller pinapple coupler, the imperial version is slightly smaller than the 8mm version, but my 8mm rod fit too loosely in the 8mm coupler, so I'm printing the imperial one. While I'm at it, I'll lengthen my threaded rod as I ended up lengthening my z axis earlier but the rod is still shorter so it eventually comes out. Also, while I have it apart, I'll be adding some lithium grease to the z axis to hopefully smooth it out a bit.
