New cutter works great, though Jason was right, cutting posterboard leaves a lot to be desired. Laser will be here eventually!
Finished building the spitfire.
My current problem is that after about 6 sheets of cutting, my clothespin is worn down into a groove about 60% of the way through so it won't last much longer. Finding a spring the right size for the shaft wasn't the easiest, finding one the right size and a stronger metal is going to be tough. I might see if I can bend my own spring out of thicker music wire.
Hey David and all y'all,
Just got my MPCNC built, running and I now know what gcode means ... sorta!
Next I need to build a needle cutter and get plane drawings into gcode.
Recommendations?
Also if anyone is interested in printing a needle cutter base out for me to get me started, I will pay!
--Glenn
Recommendations?
--Glenn
Hi folks, I made some progress with my CNC...
The small Arduino-Driver-Board is looking a kind of "funny" when compared to the big steppers...but the drivers are working fine.
Joachim
... is that some kind of H-bot setup? -- David
...not the same, but tricky too! This system reduces speed by 2:1 and increases power and resolution by 1:2.
A big advantage is the use of a single stepper for the main axis - this reduces the danger of "crabbing" (when 2 steppers are not running sycronized)
I do not have any experience with such belt drives...I think, this will be good enough for the needle and the laser...
...but if this is strong enough for real milling???...we will see :black_eyed:
Joachim
... what kind of glue is that you are using to glue up your plywood assemblies?...-- David
You may want to look back at post 242 where David builds a cutter from mouse traps. I also do not have a 3D printer (yet) so this is the route I took. Works great for me.
What plane are you looking to cut out? I have several plans ready to go in Estlcam and would be happy to share them.
Hey, Glenn. Congrats on getting your MPCNC built and running. What kind of tool mount do you have... the MPCNC stock one, the Hicwic quick-change, other?
As you have probably gleaned from reading through the thread, the needle cutter is quite easy to build using any of several techniques... and most of the recent ones should work well. Verris's bearing-based one seems to work nicely if that's the way you want to go. My sideboard version (modeled after Joachim's KISS cutter) seems to be working well though I'm still using wooden sideboards rather than PTFE/teflon and it really needs more testing. I plan to eventually put it up on Thingiverse... either a mod to the one that's there or a new one.
Also, the genuine plane builders have now shown up in force (I'm not one...) and will be a great help to you to get your plans committed to gcode. I look forward to seeing that mini-guide Verris mentioned... that should be a great help. I get by but do it so little/infrequently that I forget and have to relearn every thing every time I want to work/rework a design and generate a new cutfile.
-- David
...with the new CNC and the "KISS-Needle Cutter"
Hi...just finished the first test-run with my new build CNC and the (K)eep (I)t (S)o (S)imple version of the needle cutter.
1> --- The cutter with the thin (0,5mm) needle and the longer curved rails is working very well...there is no heating up in the guide at all.
2> --- I'm a little suprised about the precision of the belt drive...the results are better than exspected!!!
By the way...when testing the new cutter, I had a close look to the "old prototype" (cutting a few dinos and 10 or more sets of planes...
>> there is no wear within the guide or on the needle...only the tip is a little more blunt
