Well, the 2.5 hour print actually took 3 hours...and I had to take my kid to her swim class tonight so I didn't even get to start printing until after 7. And then when I did my CHIP which has been rock solid stable for several months crashed 3 times
Installed a few debian updates on it and seems happy again (except the kernel which is way out of date and can't update because I'm on a custom build and can't be bothered to build a new custom kernel but apt-get won't install a new stock kernel over my custom one...I need to just do a full wipe on this thing but am too lazy to do it.)
Anyway...finally came off the printer around 10:30 tonight and I did some mockup building. It's looking pretty good...but definitely a few things I need to tweak.
The holes in the flywheel are too loose for 3m screws. I copied David's flywheel with the technique from my video...but the cleaner 3mm holes have just barely enough meat to thread a screw into. not nearly enough for me to trust it at speed. Checked my metric taps drill size and they suggest 2.5mm holes for a 3mm tap...so I redrew the flywheel with 2.6mm holes as a compromise. We'll see how it does...may need to open those back up a bit but at least the flywheel is a quick easy 20 minute print. (The new flywheel is printing now.) I also changed it to have 16 "balance" holes instead of 15 because that allowed me to use a circular pattern in onshape to create them really quick and easy. Then I realized I had just miscounted the holes on David's original
I need to trim down those 2mm screws that will attach the flywheel. Also I guessed on the size of the countersink holes for them and was off by about .5mm so had to make them a bit larger on the reprinted flywheel as large.
You can get a bit of a feel for how it's shorter than the old one and there's less to "wiggle" unsupported out off the lever arm of the motor. And how it's taller.
I used Basscor's spacing for the bearings and it looks pretty good...I'll have more details on that tomorrow. But I tested it with both 0.62mm and 0.8mm wire (the 0.8 is what I've been using) and with the 0.8 the two lower bearings give very slight tension against the needle while the 0.62mm wire fits just slightly loose.
It's hard to show in a photo but the bearing on the flywheel with a single m3 washer behind it lines up perfectly with the hole for the guide:
The guide bearings though...don't line up so great. They're too far back. I could stack some washers behind them...but after looking closer at Basscor and Verris's setups I decided I wanted to lower the bearings closer to the guide to give more length on the unflexed needle. So I'm probably also going to push that part of the "frame" out a bit over the hole so the bearings line up better. The holes for the bearing bolts are also 3mm and screws do thread into them and would probably be safe...but I'm making them a little smaller too so I can tap threads into them...I'll probably still put nylocs on the back just for peace of mind.
I also have to take 1.5 more motors apart for their bearings and pickup a few more metric screws and washers for final assembly.
Oh...and I need to modify the quick mount a little...it's just a little loose in my machine. I need to thicken the V part up just a hair.
Overall I'm hyped though. The frame feels VERY solid removing the bottom doesn't seem to have hurt at all. In fact with the bigger sides it almost feels more solid than my original cutter body.
New flywheel just finished printing...we'll see how the hole sizes are...so I can decide what size to go with on the bearing mounts before I do a "final" reprint.
Oh...and may choose a different filament...this translucent green is neat for thinwalled stuff...but looks lousy on thicker things where you can see the infill showing through
