acp - glad you like it!
That little rack WAS pretty easy, the CAD was the hardest part. I started working on a 3 shelf version with more interlocking tabs last night (Onshape document link: https://cad.onshape.com/documents/a...371a488642326a3631/e/555ac78a6769253128418fc6 ):
Still a work in progress...not nearly as easy! The foam cutting will be...but the CAD is proving surprisingly difficult....but just after I gave up and went to bed I had a small epiphany - The original version I was able to just take my original sketches that were used to extrude the parts and export them as the DXF's for cutting. This time I tried to get a bit fancier and expanded those sketches to include extra material I'll use for wrapping around the exposed edges:
See the extra 8mm section off the bottom? Seemed quick and easy. And wasn't that big of a deal, when I did the extrusion I just unselected that portion of the sketch to eliminate it from the extruded part:
No big deal. But...then I started modeling the tabs. And things got tricky. Because the parts reference off each other. I modeled the lower shelf first, then translated it creating a copy for the middle shelf, then drew the 3rd shelf on a place referenced off the middle shelf. So far so good. Then I drew the side using a side face of one of the shelfs - again straight forward. And the back and base were also fairly easy.
But...then I realized I need that little "inner support" to support the lower shelf. And while I could have just made it a rectangle and had it rely on glue. But my big plan here was to push myself and make the whole thing tabbed. But...going back and modifying the original sketches for the lower shelf and base and side to add tabs/slots that interlock got tricky. I can't just use/project from the new inner support to place the slots because the sketch for those other parts exist in the timeline before the inner support exists. And I can't move the inner support earlier in the timeline because it's referenced off those other parts. I'm stuck in a reference loop! Arrrgh!
Just before I called it a night I realized I could use booleans on the parts so I drew the inner support with tabs/slots where I wanted it and then used a boolean operation to cut a slot into the side. Cool. Except...that doesn't modify the sketch for the side. If I was 3D printing this no big deal because the part is what I need. But I'm looking to needle cut it so the sketch is what I need to generate a DXF from. Hmmm. I played with creating drawings off the parts and those can export as DXF:
But when I import them into inkscape they're all messed up So those aren't really usable for cutting from.
So at that point I decided to call it a night out of frustration.
And then just as my head hit the pillow it hit me....it's not the cleanest solution and I'm guessing there a more "correct" solution out there I just can't figure out (probably related to the drawings) but...all I need to do is create a second sketch for the side. Instead of re-using the sketch I used to create the side I just create a sketch on the face of the final part, then use/project it's outlines...boom - I've got a sketch I can export as DXF and import into estlcam or inkscape!
So I still have a bit of CAD to do to finish the last few slots/tabs...but cutting should still be pretty quick (I'm guessing around 9 minutes with the extra parts) and the final project should be even better. But...man...this is a great example of a quick easy project ballooning into a much trickier projects without appear to actually gain much complexity!
