Jealous Quimney! Gotta talk to my friend with the lathe one of these days and see if I can't bribe him into making me a beauty like that!
David, that machine is looking great! My hobby budget doesn't start to rebuild until around Halloween right now but it's already getting earmarked for too many things
Just to prove I don't hate spindles I mounted mine up with the new improved 660 mount tonight and cut some MDF for my friends CNC in progress:
First piece off the machine, came out just about perfect. MDF doesn't pocket very cleanly...but a few drops of thin ca and a bit of sanding it should be just fine for his initial machine build:
Printing the STL of that part was estimated at 2 hours...which usually means closer to 3 since octo doesn't estimate very accurately in my experience. But on the CNC it only takes:
Yeah, the setup time is a bit longer on CNC. It took me about 10 minutes to do the CAM, compared to maybe 2 minutes to open a file and slice it for 3D printing. But still a lot less time overall. I did both the front and rear X axis plates in less than 30 minutes start to finish:
Seem to finally have a handle on my Z axis issues too - didn't even cut the blue tape (I used the tape both sides and glue the tape together method of work holding) but both parts came off easy. Did have a tiny bit of "flash" in a few areas but nothing I can't live with.
There was a slight mistake though on the 2nd part due to me trying to nest them too tightly. Which was entirely avoidable if I had saved my work in estlcam as I went along. After cutting the first part I was going to use it to reference where to put the second part - but accidentally hit open instead of insert when importing the DXF for the second plate - which in estlcam starts a new project and I hadn't saved my work so far
So I had to guestimate where I had placed the first plate on the machine. I was close...but the second plate has one little corner missing on one of it's "ears" due to me nesting it just a hair too close to the first part. You can see it on the lower left corner. Oh, and yeah the top left ear is just a tiny tiny bit too short for the same reason. But the part should still be usable.
Probably won't get to go out to the shop the rest of the week - wife has evening meetings so I'm on kid duty. But next weekend I should be able to cut the rest of his plates for him. Can't wait to see how it goes.
But I just send him David's new machine while I was typing this and now he's talking about selling his big printers and vinyl cutter to make room for that to go with his in progress CNC
