Enola_yay,
I wish I had a simple answer for you about which needle cutter to print but "ironkane" pretty well sums it up. The needle cutter is a relatively simple and flexible device but needs to be adapted to your particular machine requirements (primarily the mount tool mount)... and only you know that at this point. I will go further, however, and say read/skim the last 50 pages of this thread (vs the entire thread) and you'll probably find something you can work with... the most current information will be found in these latter pages.
Of prime importance will be to look at one of the later versions that employs a "preguide"- setup that will convert the needle's motion to straight-line, up/down, motion before it enters the main needle guide (welding tip, inflation needle, custom, etc.). This can be an array of bearings, side-boards, a wooden stack, etc and may or may not incorporate a cotton-ball oiler to help reduce friction and heating in the main guide.
I'd suggest looking at Jason's ("jhitesma") needle cutter body(s)... he's adapted the needle cutter to more machines and mounts than anybody else. Take a look at
https://www.thingiverse.com/thing:2450613
and see if that floats your boat. Please chime in here, Jason, if you are following along.
I started developing a wooden stack pre-guide setup/approach in the following post... though I now think a graduated upper-guide approach isn't desirable/necessary (a simpler 1mm upper-guide stack seems to work best)...
http://forum.flitetest.com/showthre...with-a-needle!&p=360136&viewfull=1#post360136
but I can't really tout it as better, or even "as good" as the other approaches, because I simply haven't used it to cut the amount of foam that Jason, Mark ("moebeast"), or others here, have cut. My attraction to this approach, however, is that it uses the "original" (though taller), printed, needle cutter body... without any special support structure for the pre-guide setup. It also probably requires use of a laser engraver/cutter to pull off... and I recognize many/most folks may not have one of those yet.
Please provide some information about your MPCNC and the tool mount you've used and I'm sure somebody here will be able to get you going on your needle cutter.
Welcome to the party!
-- David
PS: I see Jason has already chimed in... thanks, Jason!
