How's that machine treating you? I'm eager for an update and to see how it works!
I should have spent more time on Fusion 360 modeling the Z Gantry more precisely and saved myself a lot of idle time waiting on yet more hardware to correct those little details that kept cropping up.
It's going well now. I've decided to flush mount the Nema 17 instead of trying to squeeze in an extra inch of travel. Of course now I need to take the screw out and shorten it up.
I've got it mounted to the 2040 rail for my X and should have it back on the frame as soon as the gantry is all dialed in smooth.
Custom cables are done. I got my controller board enclosure printed and partially wired. I hope to have next Saturday to myself and not the honey-do's and I should have it moving under power if I'm lucky and not finding myself waiting on shipping again.
I'm pretty happy with the enclosure. I got the idea from an Instructable for similar board. Those Aircraft Connectors are available on Amazon for about $2.37 each. The USB extender was $5.99. I idea being that you wire it up outside of the box and then secure it inside. It probably took me around an hour to design it from scratch in Fusion 360.
I need to remove my old vacuum table and make a new one. The Harbor Freight pump is so much quieter. Hopefully it'll be up to the task of sucking down DTFB. It'll be worth the $95 I paid for it if so.
Dial it all in, design and print the tool heads (Needle Cutter, Laser, Plotter Pen) and I'll be ready to rock. Piece of cake, right? lol.
Here's the motor I'm planning on using for the needle cutter
https://www.amazon.com/gp/product/B06W9HHDZW/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
I need to extremely carefully cut off the protruding shaft so that it's flush with the face. And it occurred to me that it already came with M3 tapped hole conveniently placed about the right distance for a needle holder. Eliminating the need for a flywheel. I'm really hoping this works out.
The four bolts protruding from the Z gantry plate are for tool head mounting.
Yes, my work space is a mess.
After typing all this I feel like calling in sick tomorrow just to put a dent in this To-Do list. :black_eyed:
