Cutting foam sheets... with a needle!
TEAJR66
Flite is good
So... The machine is responding to the file that i generate from Sketchucam. I guess scaling or ratios or something is off. It did little tiny slow movements. I would have cut a 1/4" wingspan. lol.
Guess i just need to figure out what all these settings do and what relationships they effect.
dkj4linux
Is there a way to get sketchucam to generate g code that the marlin/mpcnc will use?
I've read what DKJ had to say in this response. https://www.vicious1.com/forum/topic/no-one-uses-sketchup . I made those changes and still no joy.
Trying to avoid exporting a DXF and using Estlcam.
Congrats, Tommy, on your MPCNC build. That's a nice clean-looking machine.
WRT to SketchUp/SketchUCAM... those settings you referenced have worked a treat for me in SU8. What these do primarily for Marlin-compatibility is to insert ";" for comments (vs parenthesis) and insure a Gxx is placed on every line that has move coordinates referenced. I still have SU8 because it runs nicely under Linux/Wine ("don't fix it if it ain't broke...") and I can open and edit existing design files without breaking compatibility with a flying buddy's SU8 setup.
But, in truth, I rarely use SU nowadays -- it works fine when I need it but I just don't design/cut many planes anymore -- so I've not seen fit to upgrade anything. I don't know what, if anything, may have changed with later versions but it appears many/most of the Rascal guys are using SketchUp/SketchUCAM to do their plane designs and gcode generation... so it must still be doing the job. They won't use the Marlin-compatibility too much, as they're not using the Mega/RAMPS/Marlin controller combo, but I'm sure it's still there. And with their success(es) and growth in popularity, I suspect there will be renewed interest in the SketchUp/SketchUCAM flow... especially among RC folks. I, for one, will be happy to see it... it brings back fond memories and I thoroughly enjoyed using it back in my EMC2/LinuxCNC and early MPCNC needle-cutter development days. While not for everyone, it does work and work well for RC plane builders... if that's the direction you want to go.
-- David
dkj4linux
I'm still here...
Well, I've taken a break from my "normal" activities (whatever that is... :rolleyes:) to assemble my latest toy...
This sturdy little machine will be carrying a Dewalt DWP611 router and reside with my metal-/wood- working tools out on my enclosed -- but unheated/uncooled -- porch workshop. While I've successfully laser-cut materials up to 5mm thick, this brings true plate-maker capability to the party. Not sure how much I'll really use it but it's there when I want/need it ;)
The Prusa I3 MK2S is printing a thin shim ring for the Dewalt router. The supplied tool mount was designed for a Bosch Colt and, while it supposedly works for either the Bosch or Dewalt, there is a 4mm difference in their diameters... so I'm playing it safe.
I've set this machine up with a Grbl-based controller I already had on hand from my Shapeoko2 days. I'm so tempted to put a RAMPS/Marlin controller on it just for fun but this machine really needs to be set up for what it's designed for... plate-making. After I mount the router and test/calibrate it some more, it needs to be moved out where the noise and dust won't be an issue. And it really brings back some memories...
-- David
TEAJR66
Flite is good
Got it all sorted.
Now i can go from thought to cut, all in Sketchup.
First thing i cut was my Rainbow Butterfly Princess. Worked great. Took me just over an hour to prep and cut the three 20x30 sheets that i already had laid out in SU. Just used the Sketchucam/Phlatscript plug in to define the cuts, saved the g code file to the SD card and ran the three g codes through the cutter.
Tomorrow i start the vacum bed.
TEAJR66
Flite is good
Thank you jhitesma, moebeast and dkj4linux for the help and inspiration.
simpler really is better for the needle cutter.
Michael9865
Got it all sorted.
Congratulations!
moebeast
Just wondering, what controller card are you guys using to need marlin ?
Kevin
I use a Ramps 1.4/Arduino with LCD controller. This setup gives you the option to run off an SD card without being tethered to a computer. The Marlin firmware configured for the MPCNC available at Vicious1.com tricks the controller with a fixed hot end temperature, so you don't need a thermocouple and don't get min-temp errors.
Another benefit is that you can use separate stepper drivers for two steppers on one axis. The second extruder slot is slaved to the axis of your choice.
The whole setup is $40 with A4988 drivers which have been fine for two years on my MPCNC, but I did by the better drivers for my new machine.
https://www.amazon.com/dp/B016D6DSBW?psc=1
rockyboy
Skill Collector
Can you point a brother in the direction of how to do this? I'd love to split out the load on the drivers rather than doubling up on my Y and Z axis.
Thanks,
moebeast
Thanks,
Look in the Configuration_adv.h tab for dual axis. The comments will help. I don't know if you can use E0 and E1 for X and Y, or just E1 for one of them. I found it when my Z axis wasn't working at all. I un-commented the appropriate line and moved the driver to E1 and was back in buisiness.
jhitesma
Some guy in the desert
Thanks,
Well you can only split the load on two axis because there are only 5 drivers - basically you use the 2 extruder drivers as X/Y instead. Unfortunately it's not a simple change. It requires patching Marlin and the patch was for an older version so would take some programming knowledge to apply it to the current version of Ramps, but details and the patch are here:
https://www.vicious1.com/forum/topi...e-extruder-drivers-as-additionnal-xy-drivers/
Kevin - I thought I had told you about how we're using Marlin...but then again we may have only talked about my experiences with GRBL and UGS. Marlin is a bit unconventional for CNC, there are things I really like about it and things I really dislike.
I'll get the dislikes out of the way first (So I can end on a positive note!) because Marlin queues gcode commands internally instead of just executing them as soon as received setup for cuts is a little different. Jogging the machine is somewhat annoying as you can't just use a joystick - you have to either enter gcode commands or use the LCD to tell it to move which axis how far. Gcode commands are quick and easy - but I don't run my machine tethered so I have no way to enter them (though I am looking into building a pendant that will let me access certain codes I use frequently at a single button press and am considering adding a number pad and a few letter keys so I can enter gcodes with it as well.) Using the LCD is...tedious. Some versions of Marlin the rotary encoder isn't read very accurately so it's very difficult to go one step at a time. And if you want to change from .1mm to 1mm or 10mm moves you have to back out two levels of menu then back in. As a result most people don't jog the machine under power. But that's not a great option since it's fairly easy to throw the machine out of square moving it manually - you can stop and measure to make sure the axes are still parallel but for me that leaves too much room for error. (It would probably be easier on the rascal since you have more flat/square surfaces to measure off of instead of our round conduit!)
So...I take a different approach. Instead of jogging the machine to the origin of my workpiece as normal I always start my operations from "home" where I have some collars installed on my rails that let me square the machine very quickly and easily by just pulling it against them. Then I place my work and measure the distance from tooling to the work origin and account for it when doing my CAM. It's far from ideal and makes more complex operations all but impossible. It's a big part of why I want to create my pendant so I can jog the machine with the steppers powered up so it stays square...but there's another issue.
The version of Marlin I'm currently running is a bit buggy. But...it's an old version and not recommended currently so not something most people would run into it. The problem is if I reset the coordinates "G92 X0 Y0 Z0" then the machine seems to start working ok....but....sometimes on some prints will suddenly freak out:
I'm not entirely sure what's going on when it happens...but it seems like the machine thinks it hits a limit at some point and it's internal coordinate references are confused. At first it just acted like it was hitting an endstop and thought the work was much smaller than it was. But then it went totally nuts and started doing that triangle thing.
Ryan who created the MPCNC suggests resetting the RAMPS board to zero the coordinates, but I'm not a fan of that method since it drops power to the steppers and risks letting the machine shift and go out of square. On a smaller build that's probably an acceptable risk...but my particular machine has the old Z parts that don't hold square as well and one goofy roller so it's very easy for my Y axis to go about 1/8" out of square if the steppers power down. So I use the method I described above.
Which is ok if I'm just cutting parts. With the needle and foam board it actually works out very easy since machine home lines up with where I want the origin on my work to be anyway. I just use a 1/2" wood dowel as a spacer to position my work against my spoil board and line the left edge up with the needle. Cutting parts from wood sheets isn't much more difficult, I have marks on my spoil board that indicate where I should mount my work and it's a consistent 2.5" in X and 1" in Y that I have to offset my gcode.
But it's not as accurate as being able to position the machine right at my desired origin and that makes it trickier to do some kinds of operations. I can do them - but have to jog the machine through the LCD which is tedious.
I really need to upgrade my firmware though...that should fix the issue with zeroing the coordinates and it should make the LCD work smoother. It also apparently improves laser performance. But I've been lazy about it since the machine is working so I hate to mess with it and since it's not tethered I have to disconnect the ramps and move it over to my computer or dig out a notebook and bring it out there to reflash. Plus I've customized the LCD menus to add some extra commands that are helpful for the CNC and I've been too lazy to port them to the newest version.
Now...as for what I like about RAMPS/Marlin over a more traditional CNC control setup. The big difference is that I can run untethered. No need to tie up a computer. Plus as I mentioned earlier Marlin processes the gcode - it happens on the controller not on the computer. With GRBL and other more traditional setups the processing happens on the computer and the controller is pretty dumb - it basically just translates the steppers commands and all the heavy lifting of interpreting the gcode is done on the PC. Which is why those setups generally use parallel port connections - it makes the timing easier as PC's done run a real time OS and controlling the steppers requires very precise timing. Offloading all that to a dedicated micro just makes a lot of sense to me.
But...it's still not ideal as I outlined above. And while most of those issues are magnified by my particular setup they're still somewhat limiting. There are options...for example estlcam has it's own firmware which supports RAMPS and makes it work more like a traditional CNC - but you have to be tethered which doesn't work well for me. Marlin is working on some changes to their firmware to improve things for CNC users - but they're very preliminary right now.
None of the downsides prevent me from doing anything - they just make some things trickier, slower, or more involved. On the other hand for the simple things that make up 99% of what I wanted a CNC machine for the RAMPS/Marlin setup is super quick and easy to get up and going with (especially if you're already familiar with it from a 3D printer as I was.)
Frankly I should spend some time upgrading Marlin on mine....and finish my pendant....but I'm having so much fun using the machine I just can't bring myself to spend time working on it instead of using it :D
interesting...
So your design needs all 5 drivers then?
Could you modify the design so it would only take 4? I admit I haven't looked at the MPCNC really close. Seems like you would use 2 drivers for your Y, one for your X, and one for your Z. You could use a CNC Shield (less than $20 all up) and get away from marlin..
The shield has a PWM output that would easily drive your ESC for your needle cutter. I understand you want a stand alone machine, seems like it would be smoother without marlin. I read before you don't trust windows to send your code, it has worked pretty flawlessly for me the last 2 1\2 years.
Just an idea.. Party on Garth!
thanks
Kevin
jhitesma said
"Frankly I should spend some time upgrading Marlin on mine....and finish my pendant....but I'm having so much fun using the machine I just can't bring myself to spend time working on it instead of using it :D"
lol I hear ya, agreed.. Who's got time for that.. That's the main reason It's taken me so long to get Rascal out. To many irons in the fire and to many passing squirrels.. lol
Kevin
jhitesma
interesting...
No, I only use 3 drivers. One for X one for Y and one for Z. The X and Y both driver 2 steppers. I run them in series but some people have switched to parallel for more power. I've considered trying it but don't even have my current turned up anywhere near what my steppers can handle yet so don't feel a need. But I'm not doing aluminum and don't have any plans to (Mainly due to where my machine is located and not wanting metal chips in my office!)
If I was going to move away from Marlin I'd go full Mach3...but don't have the budget for Mach3 and as a software developer myself don't have any interest in things like the sainsmart boards that come with a "license" for Mach3 which is really just pirated/hacked. And honestly...I'd probably go LinuxCNC if I went that route as I've been a Linux user for close to 25 years now (Started with SLS back before even slackware was created) and Linux is far more stable and capable of running in real time mode unlike windows.
But while I have stacks of old computers I don't really have room to set one up and don't want to deal with the hassle of configuring all that and having to boot another computer when I want to cut something. With Marlin I plug the machine in and 10 seconds later I can be cutting. Honestly it takes me longer to lookup from plugging it in than it does for it to boot and be ready to cut :D (I still need to cleanup my wiring and install my estop and some outlets for my vac and router...right now plugging things in is pretty haphazard.)
My machine has actually smoothed out a lot in the past month since I upped my stepper current. I had them running way too low and it was causing things to drag a bit on the rails. I never worried about it because the cuts were still straight and clean even if watching the gantry it looks janky as all get out. And I know that upgrading to a current release of Marlin would solve 95% of the issues I currently have...but they aren't big enough issues for me to bother with the 10 minutes it would take to reflash - so that puts how "major" the issues are into perspective ;)
And that would make the workflow smoother as well (not sure if you meant smooth referring to the machine movement - which I admit is visible not the greatest in some of my videos - or workflow.) With the current release most people can reset the coordinates no problem so using an arbitrary home point is much simpler. Ryan who created the MPCNC also has a patch for marlin out that adds dual endstop homing so the machine can auto square it's gantries - it hasn't merged into the official Marlin yet but there is a request to have it merged open. Basically you put two end stops on both axes but on the same side (So instead of one for min and one for max you have two for min both on the same axes) and it can then run the steppers individually (So I'd also have to swap a few wires so steppers are on independent drivers) and will run both sides until one endstop triggers, then only run the other side until the other goes so it pulls itself square when homing. It's a nice trick and could even be helpful on your machine - or any other that runs dual steppers on any axis to help assure the machine stays square when steppers are disabled.
I'll probably get marlin updated on mine soon....and get my pendant built....but...neither are a super high priority. Need to get an ESC and build this FT-29 and find some better material to cut new plates for my goofy danaus style quad out of - both of which are higher priorities than improving the workflow on my machine :D
rockyboy
Skill Collector
That's how I have my lowrider configured at the moment (except it's Y and Z with dual steppers), but I do intend to cut MDF and aluminum on it so figuring out a parallel driver option is on my todo list.
I also might need to double up on the X axis stepper too (which the design is ready for). That would give me six steppers to run - all could be done in series initially, but at that point I might be outgrowing the RAMPS platform entirely though. -And I have the same reservations about Mach3 as you mention.
jhitesma
Just catching up on e-mails...and see that the dual endstop code has now been submitted against Marlin 2.0 (which the Marlin team is also talking about trying to have out the door as an official release within a month or so) and the lead dev of Marlin is saying he wants to fast track merging it: https://github.com/MarlinFirmware/Marlin/pull/7943
So...that's nice to see! The submission for it against 1.1.0 has been gathering cobwebs for a month or two and I was worried the Marlin team wasn't interested in it.
:D
I tried a set of DRV8825 drivers on Rascal. Im using 1\32 stepping and they are high current. It really, really smoothed out the machine..
I think you can get a set from china cheap, if you want to mess with it. lol I know, who has the time.. Right?:p
Kevin
