dkj4linux
SnowB1,
Jason Hitesman did the Onshape CAD of a vacuum scheme we talked about back in the summer 2016 in this thread... and it's the one I used with my FoamRipper. Several design ideas were presented but the simplest was the 3 sheet stack of DTFB... bottom layer of N-S slots, middle layer of E-W slots and a top layer of holes at the intersections of the slots. All slots and holes are 1/4" (6.35mm), spaced 2" (50.8mm) apart, and centered on the sheets so that when stacked with edges aligned, all the slots and holes also align.
The sheet being cut is, of course, placed on top of the stack and vacuum applied. The whole stack sucks down to the worktable and holds the uncut sheet securely. I have found that using an inexpensive router speed control, at lowest speed setting, with the shop vac reduces the noise greatly while still providing enough suction to keep the stack in place. You may find it necessary to start suction at full-speed to "set" the stack and then reduce the speed to maintain it while cutting.
Jason's Onshape design is here ... Jason's CAD documents. This link along with Moebeast's Foam Ripper are both in the description of Jason's construction video... which I recommend watching. Moebeast's fancy printed plenum is one of the "things" he provides on his TV page.
Enjoy! And let us know of your progress
-- David
-- David
