Most likely. I've not used the 3M stuff, just the Loctite and Elmer's Spray Glue. And when I spray, I do a light coat onto the foam board. I know Dan says not to do that, but I've not had a problem with it, myself. Maybe it's the type of glue I'm using.
One thing I WILL warn about, regardless of which spray adhesive you use - it sticks to EVERYTHING. I mean EVERYTHING. If you have a glass that might get some overspray, or your table, or your cutting tools, or anything else within a potential radius of the spray, the spray glue will adhere to it. Therefore, if you're spraying, keep your workspace area clear, and maybe have something under it if you plan to spray and want it to come up - maybe an old plastic tablecloth, or a trash bag as a drop cloth, or something that you don't mind getting ruined.
