Hi All,
I'm running version 1.1 of the OSD and plane isn't gaining altitude when switching to RTH.
I have settings RTH ALT at 200 ft and RTH ALT HOLD set to N. With these settings, if plane is below 200 ft and RTH is enabled, the plane should immediately gain altitude, correct?
From manual:
You can choose to lock the height of current height or preset height
in RTH mode, if this option is set to be off(set to N), the plane will
climb to the preset height if the current height is lower than preset
value, if not, the plane will maintain the current height to RTH.
From manual:
