I used hxt 9 gram servos on the elevator and rudder, and 20 gram servos out of an old zagi wing for the ailerons.
The rudder servo was straining, and the elevator takes a lot of abuse, so I would recommend these servos all around:
www.hobbyking.com/hobbyking/store/__23594__Turnigy_MG90S_Metal_Gear_Servo_1_8kg_13_4g_0_10sec_USA_Warehouse_.html
Also, that big ply wood piece under the nose of the aircraft. Build it as is, I ripped the gear out and now can't get any strength using a smaller piece.
Build the wing as is, but with bass wood spars instead of spruce
Strengthen the H stab joint as much as possible. If you have fiber glass, glass the fuselage to H stab joint, as well as the elevator and tail skid. These fail a lot if they aren't strong enough.
I cannot reccomend a DT-750 on 4 cells and an 11x7 prop highly enough ( if you are below 4000 ft, use a 10x7 or 11x5), if you need some practice first, use a 2200 3 cell with the 11x7 regardless of altitude.
If you have any trouble, just ask, I'm usually lurking on this forum a little to much.
