So, there were a couple of things that needed sorting on the Spit after that first flight.
First up, she's definitely underpowered. That flight in the video was at full throttle, and you can see there wasn't much go in her. It's either the motor, the battery or the prop. Easy (ish) fix.
Secondly, the trim. Mark (test pilot) said he had to put in full left aileron trim to get her to fly straight. He suggested some tweaking of the aileron pushrod to get it to fly correctly.
However, I did wonder why the trim was so badly off, so I looked at the wing - it looked as though one wingtip was much higher off the bench than the other (with the belly section flat on my worktop). I measured it using the dihedral gauge from the kit, and the right wingtip is about 1in higher than the left. This must have happened when I was building the wing (although I'm sure I measured it at the time, and it was correct).
Aside from building another wing, what could I do to fix this?
I don't really want to build another wing because A)I don't have any maker foam (only Westfoam, which is heavier), and B) if I build it from Depron, I would be just as well to build another Spitfire!
