jd7792
Hi guy's,
Still waiting on hardware and electronics to finish this project, but in the mean time I thought I would seek some advise about my wings profile. As you can see in the two photos below the shape is basicall the same as most wings. It has a wing span of 30" a wing depth of 9.5" and a centre length from nose to motor mount of 11".
I notice that a lot of people use pink foam to make their KF Air Foil, but I have been limited with the foam that I have available. So I decided to use two extra pieces of depron to built the density up. While I was playing with the first part of the Air Foil I found a 3rd piece of foam that was thinner than the original foil. I cleaned it up and came up with the idea that is in the attached photo's. As it is I have a two step AF Air Foil, but I am not sure how that will work so now I need some advise before I glue everything together.
So my question is, "Will a two step AF Air Foil work?" If so can anyone tell me how it will effect the overall wing?
Please let me know what you think...
