Delta mixing for Futaba T6EX radio
I am building a versa wing, and this is the first time I have used the elevon mix with my Futaba T6EX radio. I read the manual and set it up as it says. The elevator throws are correct, however the aileron throws are opposite. I reversed the aileron servos and now the ailerons work like the elevator and vise versa. I also tried switching the servos to the opposite channel in the receiver, but had the same result in the opposite directions. Can someone help?
Craftydan
Hostage Taker of Quads
SOOOOOOOOOO close.
There are 4 combos when it comes to elevons:
Left to first channel, both normal
Left to first channel, both reversed
Right to first channel, both normal
Right to first channel, both reversed
I typically get it wrong three times before I hit the magic combo. Dunno why -- I'm consistently unlucky with this.
You appear to have to stopped on combo #3.
Honestly. Run through all 4 of these combos and one will work.
#3
I got it! I swopped the left and right servos and reversed both the ailerons and elevator and that did the trick! Completely opposite of what the manual says.
