depron A-cut?
frige
I have some 6mm Depron aero from another project.
I was considering trying to start a swapable build.
So I attempted to make an A style cut/hinge...total fail.
I can make 2 50% cuts, and hinge the foam at those points...but removing the area between the lines is problematic.
This foam has no paper on either side.
Is it possible to do?
Should I just cut the foam, and glue it without hinge?
Or get another type of foam?
-john
