Those control surface sizes don’t suit me.😏😉😂
I'm assuming you want larger surfaces, for 3-D type flying. In that case...cheat! Keep the wing and tail areas the same, but increase the control surface proportions by copying them from models you like.
Heck, the first models I designed were drawn on the back of plans I'd built, using the same areas and airfoils, but with different airframes. Just turned the plans over on a white table top and traced the important bits.
Remember that proportion guides like these were based on statistical averages of proportions for successful models. No complex aerodynamics. I modify them, as needed, when designing a model. If it's a faster model, I'll decrease the ailerons, elevator, and (maybe) rudder. If it's a slower model, I'll keep the areas at least the recommended size, but I often increase the fin and rudder areas (I like to do slips and spins).
