Designing a WWII fantasy water jet
Dr. Looping Looie
After FTFC18, I wanted to design my own WWII fantasy concept. It should be german and a jet because I have one 50mm EDF laying around. But I also wanted something special. At late WWII, Germany had almost no runways making the operation of conventional aircraft very difficult. Instead of making a VTOL that would be extreamely complicated, I decided to use natural existing runways like water. The plane could take-off and land on a river or lake or be operated ship based. Being a seaplane, it wouldnt need a carrier and could be launched from a destroyer or other ship. It should also have either retracts or a take-off dolly and landing skid for conventional ground take-off.
The EDF should be as hidden as possible in the back.
So I made some sketches of a single seater fighter:
On this pic, the side view is pretty final while air intaktes and horizontal stab of the top view will be remade:
I also made a model in Simple Planes, which is a simulator where you can build your own airplanes and it has shown the best water caracteristics yet.
Another thing are the air intaktes: they should be lokated over the trailing edge of the wing so they dont suck too much water in. I have two concepts:
1. NACA ducts: they are not too exposed and get the air very good in.
2. Normal intakes on the trailing edge: The Idea is to suck the air above the wing away creating a low pressure zone and more lift. Maybe this allows slow flying and short take-offs.
Do you have some more design suggestions?
Or name suggestions?
I hope to finish it in two weeks.
b-29er
So basically you're talking about doing a Saunders-Roe SR. A/1 with a mid wing? I mean its an option but i'd almost say unless you want to do the true twin duct, save yourself some of the design work and do something like a HE 162, use a top-mounted jet pod, since German jets were pretty lengthy back in WWII, and use a fork tail. The added advantage of the engine pod is you raise the engine above the fuselage to the point where water shouldn't get in on all but the most inverted landings. You'll also wanna either put the elevator up high or on a V to keep the water off on takeoff. If you're really going for WWII german seaplane, especially the late war craziness, i'd look at:
-fork tails like some of their midwar seaplane designs with a flatish bottoms
-multiple engine pods, maybe mounted on the top of that mid-mounted wing with some sort of a diverter to keep the inlet ahead of the wing and water out
-The DO-26, but replace the push-pull engine pods with jets
-Rather than using a mid-wing with tips, you could have a second, smaller wing to help stabilize the aircraft attached to the fuselage. This would give you more wing area to help with takeoffs, and give you a spot to put retract
gear thats relatively dry)
As for the suggestion of reducing takeoffs by putting the inlet up top, you'd be diverting the normal airflow the fuselage would be putting off anyways, so that wouldn't help much. If you wanna keep this a fighter, i'd look at keeping things sleek and helping it build up speed
rockyboy
Skill Collector
I think the design you started with looks very cool, and having seen the other designs you've built and flown I have no doubts you'll get this airborne too :D
Dr. Looping Looie
Allright, I started the build. Wing is done and fuse started.
As you can see, I used many small pieces for the spar, and its very strong.
The fuse is Just the side plates and some structure right now. Stronger parts will attatch to it later. I didnt add the bottom plate before the side plates were in place, and thats because I want to make a special angled bottom. I made a very nice seaplane last year, which I sadly didnt completed, and it also had a very nice angled nose shape which I want to recreate:
Dr. Looping Looie
Some more work on the fuse. I put the bottom on and made a reinforcement piece to shape the nose. Then I cut out a piece to put the wing in the middle. The top will later be covered by some curved pieces.
And I also calculated the CG so that I could put the step in the right place.
Here it is side dy side with the old one:
And the wing is put in:
I think tomorow it will look like something.
b-29er
That first hull design looks like it'd be awesome for some kind of 30s vintage seaplane.
Dr. Looping Looie
I actually planned it as a modern version of the Dornier Libelle with twin engines. But I had Problems with the top mounted wing, so its unfinished. Maybe I'll complete it this winter.
Dr. Looping Looie
Some more work done. Nose cone finished, tail attached and hatch started.
Here come some pictures:
The hatch is really huge and provides good excess to the inside:
This part connects the first triangular style step with the second flat step:
Next thing to do is putting some formers and curved foam on the hatch to get some good looks.
Dr. Looping Looie
I Just put the EDF in and installed elevator and rudder servos!
All I need to do now is put the rear cover/ thrust tube on, install ailerons and make some wingtip pontoons.
Edit: ailerons are also done.
