Okay so sorry for the delay, the kids requires attention. So now that they are asleep and I finished tearing up the mistakes I’ve done here is the next step.
First prep the pieces I posted on post #25, without the two this pieces which are not really needed. Then get 4 popsicles sticks cut about 1.5 inches long and two Velcro straps.
Glue the 4 popsicles sticks on the bottom part of the plane where you have the slots, make sure to glue in between the slots.
Now for the inside pass one of the velcro straps in the thin slots close the the nose of the plane, turn over and slide back in through the other thin slot paralel to the one you used.
Next take this former and glue in a c fold manner, and let it cool.
Now we’ll start putting in the formers starting with the one closest to the nose and work out way back. You don’t have to glue them down to much cause they’ll be pushed down by the bottoms covers so a drop or two of glue on the bottom is enough. Before applying glue make sure to test fit. Do the first two formers and then slide in the second velcro strap in the same manner as before. After inserting the second velcro keep inserting the formers until the end.
Once your done with that you’ll want to get the covers shaped. Most of the covers are easy to shape the only one which is a bit difficult is the tail cover, so I’ll start by explaining that. To shape it you’ll want to place the center of the piece on the edge of the table with the side without the paper facing the table. Now you want to put one hand on the top of the piece gently applying pressure on the piece while sliding the wide part down. You’ll have to repeat this a couple of times on both sides until it has the right looking shape.
For the rest of the parts just put the edge of the part one the edge of the table the side without the paper facing the table and slide the piece downward while applying pressure from the top. Repeat 2-3 times and then shape of the rest with your hand. The pieces should look like this.
Take a piece of painters tape and tape it over one of the sides of the tail cover. Now take that and line it up with the center of the double former and the edge of the tail section. Once happy tape down to the fuselage. Open up so that you can see the cavaity, then prep tape on the other side of the cover but this time place it on the fuselage not the cover and bend away.
Now apply glue to both sides of the cover and both formers and pull over and down so that the sides of the former both touch the edges of the bottom part of the fuselage and tape over to hold in place.
The next cover needs to line up the the previous one but you might need to do some trimming to the previous cover so test before. Do any trimming that you need and glue as before.
The next cover goes over the two inner formers of the two spaces formers, and is glued in the same manner as before.
Now for the last cover the one closest to the nose. You’ll want to line it up with the former closest to the first velcro. Notice that the circled former at the front of the plane is a few mm outward from the cover make sure to apply some pressure on it pushing is back to line up. This should give l the plane the right thrust angle.
When your done and remove the tape you should have this.
Ok going to cut out the pieces for the next step.
