mayan
Next step of the build here goes. First get these pieces.
Next prep them like this, clearing out cavities and pealing of the paper from side of the pieces that have a circular shape to them.
You’ll first want to address the thin piece gently curving it with your fingers or over the edge of the table. Once you have a general shape put a drop of glue on the edge, close up the edges and tape while letting it cool down.
Once cool, peal of the tape and line up the connection seam with the center bottom of the nose and prep for gluing as so.
Now apply glue around the inner circumference of the front of the nose and bring down the piece making sure to line it up all around, smear any access glue and tape while cooling.
Now you’ll want to take the rectangle looking piece and fold it up like we did before with the same looking piece that had the tabs on them. This is actually going to be the power pod, you’ll have two pieces like that; one short and one long fold up the long one even if you plan on using the c pack motor. Once you fold it over if you want that as a powerpod the glue the firewall on and then tape over like you would normally do on the ft models.
Now slide on to this piece two of the three formers and glue them together stay away from the power pod so it won’t glue to the formers. After waiting for a few seconds remove the powerpod to make sure it won’t glue to the formers.
Take this piece and roll it up against the table.
Then take the double former and slide back on and secure with tape to line up with the power pod.
Slide on the last former and take the thicker less curved cover in hand.
Take note that one side is larger than the other when rolled up the shorter end needs to line up with the double former we just built. Now line up the second former to the end of the cover and apply glue a 1/4 of the way starting from center bottom. Now line up once more and hold applying pressure on the 1/4 mark using the table and the bottom center using your hand be careful not to get burned. Hold for a good few moments before moving on.
Now apply glue on a another 1/2 of the two formers and continue rolling up using the table as your friend holding for a good while until completely dry.
Once dry roll up the rest first, trim if need, then apply glue the rest of the way and the side of the start and tape up to dry.
Now take this piece and roll it up against the table be gently because it doesn’t roll easily but you only really need to soften the foam board. Those piece wraps around the very front of the cowl. It’s longer then it should be so find where it lines up good and trim accordingly. Then glue close, tape up and let it dry.
Once dry slightly bevel cut the outside of the piece then glue on to the cowl on the side of the double former.
Now slide the whole thing on the front of the plane to check the fit then apply a few drops of glue about 1.5 inch apart from each other all the way around and push in place. Make sure to leave the power pod out a bit so you be able to pull it.
Next up is the tail section so get the horizontal and vertical stabilizers ready.
As for the wings as @kilroy07 and I discussed I will do them with the flaps.
