Differential thrust on DX8e? HELP!
Joe Carpino
Does anyone out there know how to program differential thrust on a DX8e? I’ve tried several methods but I can’t get it to work and I’m getting really frustrated.
chrisvdv
This is for the FT Legacy.
Joe Carpino
I made my own 3D A-10 and I just want to mix in differential thrust but my DX8e won’t do it for some reason
chrisvdv
Send me a copy of the model configuration on your TX, and I will impot it on my TX and have a look at the file.
Page 27 of the manual tells you how to export a model file.
Duck
@chrisvdv I am also having issues here and I was looking at the shots above compared to the dx9 guide which I had been following. It looks like you have an extra "Mix 0" for Thr>Ax1. I tried adding that and it just made Aux1 stay at -100% when I adjusted throttle.
What I see on my DX8e is with the below mix I can raise my throttle to halfway and Aux1 mirrors it. Once I go full throttle, Aux1 stays at halfway. Because I am doing a bronco I am doing Vtail mixing using the built in mix but those don't appear to use Aux1 and instead mix REL and LEL.
My behavior
Throttle Stick -100% > Thr -100%, Aux1 -100% < Good
Throttle Stick 0% > Thr 0%, Aux1 0% < Good
Throttle Stick 100% > Thr 100%, Aux1 0% < Bad
My config that gives strange behavior (attached)
Channel Input Config
Aux1: Throttle
Mix 0
Rud>Ax1
Rate 100%, 0%
Offset 0%
Mix 1
Rud>Thr
Rate 0%,-100%
Offset 0%
  • 009~9 FT Bronco.SPM.txt
Duck
The really weird thing, I also tried just using the "Channel Assign" setup as well just to verify the motors gave equal thrust. It gives the same behavior
I had thought I had it setup right for differential in Fall when I maidened my bronco but once I throttled up it pulled HARD right and resulted in a crash. That is why I was checking the mixes and noticed that above 50% throttle it just does the wrong thing. It is getting to flying season and I wanted to be ready to give it another shot once my field is no longer flooded.
chrisvdv
@Duck pm me the .spm file not as a .txt file so I can import it onto my transmitter. That way I will be able to go through the setup without guessing.
