Introducing the Grunjet, a two sheet foamboard performance jet flying fast and sporty, and slows down to a solid run on landings, and is packed with amazing vertical performance, all only costing 80$ built to BNF standards
-Video
-Parts list
two sheets of adams readi-board
FMS 50mm 11 blade EDF 4s version
4s 1300mah 45C
40a esc
three 9g servos
-Review
-Speed
I would say roughly 70mph
-Handling
smooth but fast roll rate with the same tendencies on the elevator which makes a great introduction to jets
-Slow speed
This is one of the strongest points for the design, so it comes in really slow compared to other jets in its class.
-Stalls
A little rough but I have yet to drop a wing
-Aerobatics
This plane doesn't have a rudder so you're limited to basics: rolls, loops, and inverted flight.
-Take offs
You can either do an underhand launch while holding the thrust tube, or my favorite, just plop it on the grass and give it full throttle and off she goes!
-Vertical
Nearly unlimited
-CG
4.5 to 5 in/11.5 to 12.5 cm from leading edge
-Gallery
-Plans
Grunjet Plans V1.0
-Decals
Grunjet Decals
