DIY $80 Grunjet
Grifflyer
WWII fanatic
Introducing the Grunjet, a two sheet foamboard performance jet flying fast and sporty, and slows down to a solid run on landings, and is packed with amazing vertical performance, all only costing 80$ built to BNF standards
-Video
-Parts list
two sheets of adams readi-board
FMS 50mm 11 blade EDF 4s version
4s 1300mah 45C
40a esc
three 9g servos
-Review
-Speed
I would say roughly 70mph
-Handling
smooth but fast roll rate with the same tendencies on the elevator which makes a great introduction to jets
-Slow speed
This is one of the strongest points for the design, so it comes in really slow compared to other jets in its class.
-Stalls
A little rough but I have yet to drop a wing
-Aerobatics
This plane doesn't have a rudder so you're limited to basics: rolls, loops, and inverted flight.
-Take offs
You can either do an underhand launch while holding the thrust tube, or my favorite, just plop it on the grass and give it full throttle and off she goes!
-Vertical
Nearly unlimited
-CG
4.5 to 5 in/11.5 to 12.5 cm from leading edge
-Gallery
-Plans
Grunjet Plans V1.0
-Decals
Grunjet Decals
jaredstrees
Afternoon Grifflyer! I’m going to start my build on this tonight. Any tips? The batteries and esc I have are a little big at 1500mah and 60 amp esc, but I’m using gorilla glue to shave a little and I’ll probably shave a little more weight where possible. Looks like a great plane and am looking forward to the build/flight!
Grifflyer
WWII fanatic
#14
Personally....I think you'll be fine, I run on a 1300 and a 40 amp with NO regard to saving weight and it comes in SO slow. So, I think you might not come in as slow, but you'll get a bit more power and make the ground takeoffs even more fun! The only tip I've got is make sure your thrust tube is straight,
And I should probably mention control throws.
Ailerons Low=~15 degrees | High=~24 degrees
Elevator Low=~11 degrees | High=~20 degrees
jaredstrees
Probably not the decals, I'll add some color to it, most likely just a little colored packing tape for orientation. After the maiden and I get a handle on it's flight characteristics I'll most likely build another and really dress her up. Seems like it should be pretty straight forward and quick build. If you get a chance though, could you take a pic of the bottom so I have a 360 view for the build? If not I'm sure I can figure it out.
Grifflyer
WWII fanatic
#18
sorry I'm a little late but here are some pictures from lots of different angles
make sure the tail tapers down to one sheet of foam thick.
