DIY simulator Cable
bapanyabakabon
This past days I've been searching a simulator cable for my FS-I6, and I have found interesting cheap DIY cable, lets get to it
what you need
1. Audio Jack
2. PCB pin ( I dont know the term, but this guy
3. Audio/mic splitter (this guy s-l300.jpg
you need to connect the top (left audio) and ground to the PCB pin ( just 2 cable)
and it look like this
now those pin must be inserted the ground cable to ground port (it s the ring), the left audio cable to ppm port
if you have 2 port (mic and audio) in your PC/laptop you can pluged in to mic port,
but if you have only 1 port (mic/audio) on your laptop you can basically disabled front panel jack detection and to do that you can using realtek audio manager like this guy https://mirkofpv.blogspot.co.id/ or using this method
Uninstall your audio drivers until you have the Windows default audio driver installed. (High Definition Audio Device 10.0.15063.447 )
Press Windows Key + R
Type regedit, press enter
Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E96C-E325-11CE-BFC1-08002BE10318}\0007\GlobalSettings
Right-click the REG BINARY EnableDynamicDevices, click Modify, and set it to 0
Reboot.
hope it will help
agupt108
what you need
1. Audio Jack
3. Audio/mic splitter (this guy View attachment 101372
Reboot.
and use this guy View attachment 101372
hope it will help
Do you know if there is a way to do this for a transmitter that does not have a ppm port?
Stetonion
Can u elaborate a bit, if u don't have a trainer ppm port what else do you have in ur transmitter any audio jack or something like that ?
If u have a transmitter that u get with a RTF, most likely u will not have those, but still if u have a arduino microcontroller and some soldering skills u could use ur transmitter.
I think this video could help u more on this regards
Stetonion
what you need
1. Audio Jack
Reboot.
hope it will help
A great setup I would say and with ur audio jack splitter idea I could finally connect my Tx to a laptop, but I want to give u a tip try connecting ur pin (which ur are connect to the Tx directly) directly to ur receiver and enable ppm out in your Rx setup menu in your transmitter, in this way u could use ur transmitter wireless 😉
