DJI Downlink + Fatshark FPV
vk2dxn
Do you have a wiring diagram for your AV tx?
The three wires should be ground, Video, Audio.
If you can find out which pin is what then you can wire up a female stereo jack to the gopro cable I posted before.
The cable you have now seems to be a normal mini USB, the gopro connector has more pins
vk2dxn
The top part of the first picture has a different cable than you describe. Yellow wire is video and black is ground.
Fenomnis
as i said the top pic is the same tx and rx but it has some other cables
hm this would be to complicated for me... :/
