I butchered my Phantom after it crashed into the ocean, I even used 2 "normal" ESC's and 2 of the remaining phantom ones, everything works fine together.
The motors are in the 900kv range (920 for stock) so they won't like spinning tiny props very fast.
I stuck the components onto a 450 frame from hobbyking but I chopped down the PDB as it's quite large, I only left the voltage regulator and then simply wired up the ESC's to a circuit-board PDB.
The NAZA can also run in full manual mode which is how I fly the 450 quad frame, I use it as an FPV practice bed and I stuck 11 inch props on it as it's more of a slow cruiser.
Let me know if you want some images or something, or if you need help.
Cheers
