bracesport
@Wildthing - watching too many YouTube videos!
SlickFirst test of the moulds this morning - this is the fibre glass nose cone - I am working up to the more complex carbon parts! There is three layers of very light FG cloth - the middle layer is with the grain and the outer layers are biased to the grain - it seems to work pretty well just using a brush to dab everything into place - the extra glass on one half is obviously for the joining seam - the balloon seems to be holding pressure well - so far so good.
View attachment 201255 View attachment 201256 View attachment 201257 View attachment 201258 View attachment 201259 View attachment 201260
Do you grease up the molds at all so the pieces come out easy?
Possibly the heat generated is actually melting or weakening them causing it to burst. There must be different quality of balloons out there, never looked myself but I know over the years you would get some that would break and you hadn't even blown it up totally yet.My biggest issue is I’m bursting the balloons during curing, I suspect I am using too much pressure unnecessarily! As long as I get 4hrs curing it seems to be ok but it would be good to perfect the system!
When are you going to start selling them ?@Wildthing - yes, after this round (and given it works) I will definitely make the moulds even better! I originally thought the parts would not release that easily, but given the success the process can be improved incrementally - I also have to perfect the amount of material used to make the parts lighter!
