bracesport
the fuse and tail printing want well - I hope I can get the CF boom and servos in this week - to aid assembly I plan to use servo stoppers!
I just did a experimental piece. Oh, bare foam when you get it really hot it will stick to normal paper , basically you can melt them together. ( with me not using FB I don't want it to stick so I experiment with different paper and parchment paper is just awesome, I can melt the crap out of the foam and they won't stick together. The reason for me to use paper was because I was using the sock and it would stick and I didn't want to get the iron filthy. The initial picture shows four layer but I took one off, the second & thirdUsing the iron at work I tried again - sadly it had a little water in it and created a bit of steam - the steam loosened the paper, but still did a great job on the tapers, so you guessed it I peeled the paper and glued the halves foam to foam as shown below.
currently waiting for the Gorilla glue to set!
here is the sample from the info @ post#123 - actually it worked a treat - this wing foil is 165mmx11mm for the DLG - there is no spar, just a two sheet lamination a-la flyboa - no sanding other than the LE cap!
@flyboa - now I need to try a full wing!
I printed the templates for the wing and tail feathers - it is time to get busy and build me a fuse (still need to find some 2mm balsa and some more FB)!
View attachment 135174 View attachment 135175 View attachment 135176
The baking paper is probably the same as parchment paper. You can get the foam to molten lava and it doesn't stick .in making a lightweight wing in the style of flyboa we would remove the paper from the faces that are gluers together - if we use the ironing method the paper re-sticks to the foam when it melts - today I removed the paper and used baking paper between the iron and the foam which works well - progress!
