bracesport DLG
bracesport
As a reference the first fuse was 108g AUW so the goal will be to go under that and with a lighter tail for better balance.
Wildthing
Finally started to tear it apart and cut out some new wings
bracesport
@Wildthing - I am out for a week with work so I will not have any more progress till October kicks in - yours is looking good though - with the second wing I made, and given the ailerons are bottom taped, I also tapered the tips from about 20cm out.
BTW - I ordered an iron so I can try the shrinking film!
Wildthing
I am just slowly tinkering away, weather permitting I am busy at work right now, people getting in a panic to finish their projects before winter hits.
For the covering I am just using the cheap HK iron on stuff, price is right and because it is the only stuff I have tried I don't know how much better/lighter the good stuff is :ROFLMAO::ROFLMAO: .
bracesport
@Wildthing - I recognise your aileron technique from the Baron - How is the CG - mine was tail heavy before the rebuild, but the second attempt is looking much better! 😀
Wildthing
It is better but still a tad tail heavy, used less weight to balance it but now I am going to move the cg back a bit , then try to find some tall grass and see if it just glides before I try the discus launch.
bracesport
@Wildthing - I tried glueing the foam with gorilla glue to the PLA as a test for mounting the wing the other day - no go fell right off - how is your wing mounted?
