Are you trying to calibrate through the Pixhawk, and using the classic technique of having the throttle stick high when you plug the battery in, then lowering it. If so, that won't work as calibrating ESCs through the Pixhawk requires using the special ESC calibration wizard in Mission Planner (assuming you are using that). Otherwise you can hook the Kiss ESC directly to a receiver and calibrate using the classic method.
