leaded50
Experimental pusher fighter. Project. V-1710 liquid-cooled engine, rated at 1,100 hp at 30,000ft, driving contra-rotating propellers via extension shaft
Work on this unusual design started in in 1939. In order to keep the fuselage aerodynamically as clean as possible the engine was mounted in the mid-fuselage, driving counter-rotating three bladed pusher propellers via an extension shaft. Another advantage of the buried engine was enough room for heavy cannon armament in the nose. Thus the pilot had an excellent view and a wide field of fire. Although this fighter project was never realized it was the basis for many other pusher-type aircraft
My model gonna be:
length 830mm
wingspan: 126.5mm
motor: 2822 1000kv (sorrry, but not any contra- rotating props... pricetag raised too much)
My model gonna be:
length 830mm
wingspan: 126.5mm
