Downloadable Plan FB Middlestick
SP0NZ
FT CAD Gremlin
Admin
Hotwax, thanks for sharing your plans. This plane looks great. I'm building one for my dad as a Christmas present. I want to build the non-swappable version, but plan to build it as a tail dragger. I do have a question though (and maybe more as I get into the build a bit more). Does the firewall just get hot glued into the fuse?
hotwax
Yes, they are.
The inner walls are 5 mm shorter than the outer ones. So you get a lot of area for the gluejoint. If you give it a final beed of glue at the front- and the backside, it will last forever.
Werner
xuzme720
Dedicated foam bender
Ahh ok. I thought it looked familiar!
Good luck with your computer. I just had an issue with mine a week or so ago...
SP0NZ
FT CAD Gremlin
Admin
Thanks Werner. I cut a firewall from AC ply and glued is in place to mount the motor. I went with the same setup that you showed for your maiden; Turnigy 3536/8 1000kv, 40A Plush ESC, and 2200 mah 4s. What prop did you use with that setup? I've got a 10x6 on it now, but any advice you have would be appreciated.
Yes, they are.
Werner
SP0NZ
FT CAD Gremlin
Admin
Build is about 90% complete. We are giving it to my dad on Christmas Eve, so I need to finish is up and wrap it soon. Here's a picture of her so far.
The picture makes the plane look blue, it's actually purple (my dad's favorite color).
hotwax
Hi SPONZ,
good Job!!!!!!
A 10 x 6 prop will be perfekt. For actual flying, use 4 to 6 rubberbands.
Merry Christmas
SP0NZ
FT CAD Gremlin
Admin
Hotwax,
Thanks again for posting the plans. My dad's a huge WWI nut and I think he's going to love this. Will definitely use more (and bigger/better) rubber bands for flight. Hope to get the wing tapped tonight. I will post a couple more pics when she's complete. I have a suggestion for locating the wing. I'll post that latter with some more pics.
SP0NZ
FT CAD Gremlin
Admin
Top of the wing is finished. I still want to go back and add the black accent stripes to the fuse and the wing, but I think it's looking pretty good already.
SP0NZ
FT CAD Gremlin
Admin
Hotwax,
You did an amazing job with this design! I put her up for her maiden flight yesterday and it flew amazingly well. Only a couple clicks of trim and it was dialed in. At WOT it's pretty quick, but it also glides forever with almost no power. Thanks for sharing the plans.
Flynn
Heya Sponz, Great Plane! Great seeing you flying it at FF. I was wonder how many rolls of tape is needed for a finish like yours? Also, how did you do the crosses?
Thanks for sharing the plans Hotwax, I'm printing them out now.
SP0NZ
FT CAD Gremlin
Admin
Believe it or not, it was less than 1 roll (of the big rolls from TapeBrothers.com) for the color. For the "decals" I printed them out on an inkjet printer and spray glued (3M Super 77) them on then covered with clear tape. It takes a while to do a plane this big, but the paper is completely covered. On the one shown above, I used black electrical tape for the black accent stripes.
butch b.
How come when I try to print plans from your site, the red does not print, but my printer will print the red from other sites that I get scale plans from.
CMS_1961
CMS_1961
Hotwax
Nice job!! Depending on motor used, I believe this will be an awesome trainer or speed liner!!
Thanks for the plans!!
hotwax
Sorry to hear. There where no such complains yet. The plans are stored at Flitetest.
Please check that you have installed the latest Adobe Reader and Printer driver.
