Vimana89
It is very light. 3mm Depron planks over Depron formers and ribs. It has a balsa spar. Otherwise completely hollow. Motor batteries in each nacelles so the wing is off loaded in flight. No undercarriage so hand launch/belly land to save weight. Low roll rate even though the ailerons are slightly extended. It can even be
looped - with care!
Very nice build, great footage, and nice flying too. It appears to be very stable, and the banks look gentle and clean. The loop seems to have taken a bit more effort and precision to pull off than with more aerobatic types of planes, but again, very clean and graceful. Turns out I'm already subscribed to your YouTube channel, just been pretty busy with builds and stuff lately and haven't checked out everything in my feed, so this is the first time I've seen the Q400, but I'm already a big fan of your HP-115. I've got to say, aside from obviously having a lot of experience in the hobby and some impressive designing and building skills with a lot of attention to detail, you also, in my opinion, have great taste in planes
. You've definitely built a couple of my all time favorites and it's cool to see them so scale.
I've been in the hobby less than a year and I'm nowhere near that level. I've built a RET slender delta that's somewhat like an HP-115 crossed with a high-mounted pusher prop trainer plane, and strange as it is, it flies very well and is pretty easy to control, even battered and repaired numerous times with tons of glue, and hardly a precision job to begin with. There's pretty much no way to stall this thing in a way that it can't immediately recover from, and landings are almost too easy with the ground effect. It's actually a very flexible and forgiving plane, I can fly it high and fast, low and slow, ridiculous high alpha, etc. A twin engine airliner plane will be a whole new ballgame for me though, and I'll have to learn some things as I go.
I'm still working with dollar tree foam board and mastering the most basic building techniques like A-folds and a few basic curved components. I'll be attempting my Q400 with the skills and techniques that I have at my disposal now, but if it turns out that's not enough and it doesn't seem feasible, I can put the project aside until I have the skillset to take a different approach, whether its rolling foam board like the FT master series, or trying my hand at Depron. Anyways, thanks for sharing your insight and experiences!
