Here are the D sized plans for my latest revision of my Grumman Goose build. The 4th sheet are out of 0.125in plywood and are technically on a C sized sheet. I will try and get some tiled 8.5in x 11in plans uploaded soon. Reference Sponz's plans key for what cuts are intended to be.
There are 3 different layouts for the replaceable nose section since I haven't decided on which method I like best yet. Also the tip floats are not included as I am not yet satisfied with how they go together.
I am also working on doing so 3D printed cowlings, tip floats, and skins for the nacelles but don't have them completely modeled yet.
I don't have many pictures of the build since this is still a prototype and hasn't been test flown yet. If all goes well I will be building another final rendition once test flying has been completed and take pictures of the build steps (if I can slow myself down enough to take them. I tend to get carried away once building starts)
Please post any questions if you try and build this. I will see if I can get pictures of my current prototype to help clarify them.
Also remember this is intended to be a "mini" sized kVbuild. My current power setup are 2205 2522kV motors. My previous build flew on 2204 2300kV motors and 6x3 props. The power was more than sufficient with these motors on 3S. My current motor swap was more of a "because I had them laying around and you can always use more power ;p" situation than feeling any need for an increased power setup.
