Slick1855 submitted a new resource:
DTFB - Mini drak - Mini drak clone, comes with normal vertical stabilizers and tail boom.
Read more about this resource...
Plans are for my dollar tree foam board mini drak replica. Plans include both normal vertical stabilizers and a tail boom setup. If using the tail-boom, reinforce the boom arms with BBQ skewers.
Specs:
-2x 12g servos (3 if using the tail-boom config)
2812 - 1100 to 1450kv motor (1100kv works fine with a 4s, I would not recommend 3s)
8x5 prop
Balances with a 4s - 2200mah or 3s - 3300mah battery all the way up front with my FPV camera and transmitter in the nose.
CG is 15mm from leading...
