Crawford Bros. Aeroplanes
I've had this idea bouncing around in the back of my head for a while now and finally decided to start on it. I've seen a few guys build boats out of DTFB and even cardboard and it seems to work better than you'd expect as long as it's sealed tight. Usually some thick coats of the right paint is enough.
RC sailing has interested me for a long time. When I was a kid I liked watching the old men sail their handcrafted boats at a park I lived by. After a bit of research on the internet I stumbled across a popular design by Tippecanoe Boats called the T-series. Tippecanoe makes this design in a few different sizes with the most popular being the 37" T37. It's a beautiful balsa-hulled design that's remarkably lightweight, leading to good well-rounded performance.
One of the things I liked most about this design was how simple the hull is. It's only 4 panels in total, the keel is flat-bottomed and the deck is straight. Clearly very easy to build in foam board. 37" is an odd size for DTFB so I scaled it down to 29, a nice midpoint between the full-size T37 and the travel-size T27. After only an hour or two I had a decent hull finished.
On its side, showing the flat keel:
I didn't get an pics before I took it out to the shop but I also fabricated the rudder. I used 1/8" balsa for the core and set a piece of 1/8" welding rod as the shaft. I then laminated a piece of cardstock on either side and sanded it into an airfoil. It's currently drying after being sealed with epoxy resin.
For the rigging and running gear I'm using some dowels and balsa that I'm sharing with my other boat project. Sails will probably be cotton, I may use a bedsheet I brought back from MCRD. It's their fault, they issued me two.
